How to get caller info (caller ID and called Nr.) from telephony presence events?
Whenever you want to be able to find out the Caller ID or the number being called during the progress of a call you can use this example:
var subscription = rcsdk.getSubscription();
       console.log(msg.body.activeCalls[n].from); // activeCalls is array
        console.log(msg.body.activeCalls[n].to);
    .register({
       events: ['/account/~/extension/~/presence?detailedTelephonyState=true'],
    .then(...);
  • October 1, 2015
Please can you provide an example as how I can achieve this via PHP/MySQL system.
  • July 13, 2016
TT
As I can see there is no such rcsdk.getSubscription(); method found in C# sdk . Am i missing something or Please guide me which SDk i have to use
  • July 13, 2016
TT
If you are using the C# SDK, it is recommended to ask questions pertaining to it using the Github Issue tracker for the associated repository. In the case of the C# SDK, that is here: https://github.com/ringcentral/ringcentral-csharp/issues
