Identify incoming call party details from telephony session webhook
  • December 9, 2020
  • 195 views
How to filter out or identify only the incoming calls to a particular extension from Telephony Session webhook. I need to identify it before it ring to the dialled extension(reception extension). Then I will route the call to other extension depending on on my custom logic, with out ringing that reception extension phone.
I have used active call list, but it ring the extension before gets routed to other extension. Can you guide me how can I achieve the expected outcome?
Thank you.
  • December 10, 2020
Read this blog and pay attention to the "Call statuses and how to use them" section. You can take action as soon as you get the "Setup" status event.
