Inconsistent Telephony Sessions Extension Events Schema
  • January 30, 2025
  • 161 views
[{'type': 'ServerNotification', 'messageId': 'xxxxxx', 'status': 200, 'headers': {'RCRequestId': 'xxxxxxx'}}, {'uuid': 'xxxxx', 'event': '/restapi/v1.0/account/xxxxxx/extension/xxxxxx/telephony/sessions', 'timestamp': '2025-01-29T14:17:14.428Z', 'subscriptionId': 'xxxxxx-xxxx-xxxx-a9f4-xxxxxx', 'ownerId': '63047761004', 'body': {'sequence': 3, 'sessionId': 'xxxxxx', 'telephonySessionId': 's-xxxxx', 'serverId': '10.13.121.172.TAM', 'eventTime': '2025-01-29T14:17:14.308Z', 'parties': [{'accountId': 'xxxxx', 'extensionId': 'xxxx', 'id': 'p-xxxxx-1', 'direction': 'Outbound', 'to': {'phoneNumber': '+xxxxxx'}, 'from': {'phoneNumber': '+xxxxxx', 'name': 'xxx xxxx', 'extensionId': 'xxxxx', 'deviceId': 'xx'}, 'status': {'code': 'Answered', 'rcc': False}, 'park': {}, 'missedCall': False, 'standAlone': False, 'muted': False}], 'origin': {'type': 'CallOut'}}}]
Another event with the same status but recordings field added
[{'type': 'ServerNotification', 'messageId': 'xxxx', 'status': 200, 'headers': {'RCRequestId': 'xxxx'}}, {'uuid': 'xxxx', 'event': '/restapi/v1.0/account/xxxx/extension/xxxx/telephony/sessions', 'timestamp': '2025-01-29T14:17:24.135Z', 'subscriptionId': '1f528df6-xxx-4dbe-xxx-xxxxxx', 'ownerId': 'xxxx', 'body': {'sequence': 7, 'sessionId': 'xxxxx', 'telephonySessionId': 'xxxxxx', 'serverId': '10.13.121.172.TAM', 'eventTime': '2025-01-29T14:17:24.063Z', 'parties': [{'accountId': 'xxx', 'extensionId': 'xxx', 'id': 'p-xxxx-1', 'direction': 'Outbound', 'to': {'phoneNumber': '+xxxx'}, 'from': {'phoneNumber': '+xxxxx', 'name': 'xxx xxxx', 'extensionId': 'xxx', 'deviceId': 'xxxx'}, 'recordings': [{'id': 'xxxxxx', 'active': True}], 'status': {'code': 'Answered', 'rcc': False}, 'park': {}, 'missedCall': False, 'standAlone': False, 'muted': False}], 'origin': {'type': 'CallOut'}}}]
Where can I see the event structures or different event types which can help me handle such status accordingly?
  • January 30, 2025
The first event with the status.code:”Answered” without the ‘recordings’ object is the event when the call is answered. Then you will get more events with the same status.code:”Answered” with the ‘recordings’ object when the call recording started (active:True), paused (active:False), resumed (active:True) or stopped (active:False).
So if you only need to identified when the call is answered, grab the first “Answered” event, get the timestamp or any data you need, and ignore other subsequent events with the “Answered” status and the ‘recordings’ object.
  • January 31, 2025
Thanks for answering ​@PhongVu  Do you have any opinion on this as well:
  • January 31, 2025
Answered in the other thread. not sure why I missed that question :).
