Is there an API to obtain call time and number of calls per user and queue?
  • August 23, 2022
  • 515 views
Good day everyone, the project on which i'm working wants to create a simple metrics dashboard per user, the idea is to obtain the talk time coming from a specific queue per each user and also the talk time for all calls received by the same user.
I looked at the call logs endpoint and using the legs I can determine who was the user who answered the call from a queue. For the total talk time, i call the call logs but pointing to the user extension.
The thing is that the call logs endpoint has a small rate limit, and i wanted to know if there's a better approach to handle this requirement
Best answer by PhongVu
Unfortunately, there is no API to obtain those call metrics. The Analytics API provides only aggregated data, and the Call Logs API is a call history which is not meant for detailed analytics.
If you are interested, you can implement your own app to calculate those metrics from real-time call data. Read this article to learn how to use the telephony session event notification to generate own call data.
View original
  • 2328 replies
  • August 24, 2022
