JS SDK incorrect header check error after move to vite
  • May 8, 2023
  • 202 views
We recently upgraded our app from vue2 to vue3 which also include moving from webpack to vite.
On webpack we were using following code to login:
platform
  .loginWindow({
    url: platform.loginUrl({ usePKCE, redirectUri }),
  .then(rcsdk.login.bind(platform))
  .then(res => {
    const data = res.json()
    store.dispatch('saveRingCentralToken', data)
Now it doesn't work. I'm getting following error
I compared request headers from vue3 and vue2. vue3 app is missing cookie headers.
From what i know vite doesn't work well with old node packages and my suspicion are the polyfills, but it's above my frontend knowledge.
  • April 18, 2024
@Pat Golan Did you get this working? I have the same problem but with react/vite. I installed nodePolyFills from vite-plugin-node-polyfills.
