Need some help with Fax API
  • December 26, 2024
  • 7 replies
  • 34 views
Hello,
I need some help with the fax api setting up.
We want to integrate the fax api with our current Java/Node Environment.
Is there any instruction about that.
  • 2312 replies
  • December 27, 2024
Check out this dev guide and see the sample code in your interested language.
  • December 27, 2024
Thank you very much!!
  • December 27, 2024
I keep getting this error, have no idea how to fix it? any help?
  • 2312 replies
  • December 27, 2024
It must be your environment. What programming language and how to you call the API? Share some code snippets and the app client id.
  • December 27, 2024
for the sms api, it ran successfully.
for FaxAPI, it passed the auth, but then it failed.
const RC = require('@ringcentral/sdk').SDK
const path = require('path')
require('dotenv').config()
// Instantiate the SDK and get the platform instance
var rcsdk = new RC({
server: process.env.RC_SERVER_URL,
clientId: process.env.RC_APP_CLIENT_ID,
clientSecret: process.env.RC_APP_CLIENT_SECRET
var platform = rcsdk.platform();
/* Authenticate a user using a personal JWT token */
platform.login({ jwt: process.env.RC_USER_JWT })
// For the purpose of testing the code, we put the recipient number in the variable.
var RECIPIENT = process.env.SMS_RECIPIENT
platform.on(platform.events.loginSuccess, function(e){
send_fax()
platform.on(platform.events.loginError, function(e){
console.log("Unable to authenticate to platform. Check credentials.", e.message)
process.exit(1)
Send a high resolution fax message to a recipient number
async function send_fax() {
try {
const FormData = require('form-data');
const fs = require('fs');
const formData = new FormData();
// Fix: Changed the JSON structure to match API requirements
formData.append('json', JSON.stringify({
to: [process.env.SMS_RECIPIENT] // Remove the phoneNumber object wrapper
// Rest of the form data remains the same
formData.append('attachment', fs.createReadStream('./fax.pdf'), {
filename: 'fax.pdf',
contentType: 'application/pdf'
let endpoint = "/restapi/v1.0/account/~/extension/~/fax";
console.log("Sending fax to:", process.env.SMS_RECIPIENT);
var resp = await platform.post(endpoint, formData);
var jsonObj = await resp.json();
console.log("Fax sent. Message id: " + jsonObj.id);
// Add back the status check
check_fax_message_status(jsonObj.id);
} catch(e) {
console.log("Error sending fax:", e.message);
process.exit(1);
Check the sending message status until it's out of the queued status
async function check_fax_message_status(messageId){
try {
let endpoint = `/restapi/v1.0/account/~/extension/~/message-store/${messageId}`
let resp = await platform.get(endpoint);
let jsonObj = await resp.json()
console.log("Message status: ", jsonObj.messageStatus)
if (jsonObj.messageStatus == "Queued"){
await sleep (10000);
} catch (e) {
console.log(e.message)
const sleep = async (ms) => {
await new Promise(r => setTimeout(r, ms));
I am using the same credentials as sms api.
here are some settings.
Thanks!
  • 2312 replies
  • December 27, 2024
You passed the string instead of a buffer? Also the ‘to’ is an array of object with ‘phoneNumber’. Try this
var FormData = require('form-data');
var body = {
      to: [{'phoneNumber': RECIPIENT}],
      faxResolution: 'High',
      coverIndex: 0,
formData.append('json', new Buffer.from(JSON.stringify(body)), {
        contentType: 'application/json'
formData.append('attachment', require('fs').createReadStream('./fax.pdf'));
  • December 27, 2024
Thank you so much, it is working now.
