I start up the websocket process to capture events from given extensions. The intention is to have a long running websocket that. However, after a bit (~10 minutes) of getting events properly, I recieve this:
Create connection error event triggered!
received 1000 (OK) Bye; no close frame sent
And no more events are received.
Here is the relevant code:
# more callback functions above...
def create_connection_error(self, data):
print("Create connection error event triggered!")
print(data)
async def init_web_socket(self, tele_sess_callback, tele_state_callback, extensions):
self.login()
web_socket_client = self.sdk.create_web_socket_client()
web_socket_client.on(WebSocketEvents.connectionCreated, self.on_web_socket_created)
web_socket_client.on(WebSocketEvents.subscriptionCreated, self.on_subscription_created)
web_socket_client.on(WebSocketEvents.receiveSubscriptionNotification, self.on_notification)
web_socket_client.on(WebSocketEvents.createSubscriptionError, self.create_subscription_error)
web_socket_client.on(WebSocketEvents.recoverConnectionError, self.recover_connection_error)
web_socket_client.on(WebSocketEvents.createConnectionError, self.create_connection_error)
#web_socket_client.run_forever()
extension_events = self.get_events(extensions)
print("Following events added to webhook: " + str(extension_events))
await asyncio.gather(
web_socket_client.create_new_connection(),
web_socket_client.create_subscription(self.get_events(extensions))
print("I/O blocking web socket ended")
def start_init_web_socket_thread(self, tele_sess_callback, tele_state_callback, extensions):
loop = asyncio.new_event_loop()
asyncio.set_event_loop(loop)
async def async_init_web_socket():
await self.init_web_socket(tele_sess_callback, tele_state_callback, extensions)
while True:
loop.run_until_complete(async_init_web_socket())
def register_call_logging(self, tele_sess_callback, tele_state_callback, extensions):
self.tele_state_callback = tele_state_callback
self.tele_sess_callback = tele_sess_callback
thread = threading.Thread(target=self.start_init_web_socket_thread, args=(tele_sess_callback, tele_state_callback, extensions, d))
thread.daemon = True # ensure process terminates when main thread completes
thread.start()
It was to my understanding that the sdk handles heart beats, and I canβt understand the createConnectionError function getting triggered, because looking at the source code of the SDK, I only see that triggered when new websockets are instantiated.
