RingOut permission not passing graduation requirement
  • July 5, 2016
  • 6 replies
  • 661 views
We have created an app in developer.ringcentral.com with oAuth permission for Ring Out. The RingOut calls using the API works fine. But even after multiple use the Graduation Requirement for "Exercise all requested permissions" is still showing Red Cross which is not fulfilled. Not sure what we might be missing.
  • Found Your Voice
  • July 6, 2016
Have you executed 20+ RingOut API requests successfully within the past 48 hours?
  • July 7, 2016
Hi Benjamin, Yes we
have made more than 20 calls. But the last requirement does not change at all.
Have attached a screenshot too.
  • July 7, 2016
  • Found Your Voice
  • July 7, 2016
I have submitted a request to our engineering and platform team to see what is causing this issue. As soon as I hear back from them, I will provide you with the updated information (because your application data looks good from what I can see, and this may be a bug).
  • Found Your Voice
  • July 12, 2016
We have identified the potential cause for this issue and are actively working on a fix for this.
Once the fix is in place I will post here so you can retry.
  • Found Your Voice
  • July 13, 2016
Please see if the "Apply for Graduation" button on the Status & Review page of your app is enabled now.
If it is not, please be sure to check that you have met all the criteria, and if you have please share the screenshots of your analytics, permissions, and the Status & Review page please.
