Update Extension - hidden field does not update
I'm trying to modify the 'hidden' field with Update Extension API and I cannot get the value to change. I see the behavior when using the API in my app as well as via the 'try it out' button on the web page. Is there some other requirement to get this field to update? An example use case is the user shows up in the company directory but we want to change hidden to 'true' from 'false'. The API response returns a 200 but the field value does not change.
Best answer by PhongVu
Does your app have the "EditExtensions" permission? Can you also print out the response to see if it get changed
View original
  • 2317 replies
  • October 7, 2021
  • October 7, 2021
Hi - yes the app has 'Edit Extensions' - I am able to update other fields just fine. rc-image002.png
Example of an update that worked:
Let me know if you need anything else - thanks!
