Webhook Incoming Call All Users In Organization
  • July 10, 2019
  • 11 replies
  • 2171 views
I'm creating an app for my organization that does a handful of customized things that RingCentral does not do. This is my first time to use the RingCentral API and I'm stuck on how to get the Incoming Call webhook to work for all extensions in my organization. I'm using the .NET SDK and right now I have:
var rc = new RestClient(CLIENT_ID, CLIENT_SECRET, SERVER_URL);
await rc.Authorize(USERNAME, EXTENSION, PASSWORD);
await rc.Restapi().Subscription().Post(new CreateSubscriptionRequest
     eventFilters = new[] { "/restapi/v1.0/account/~/extension/~/incoming-call-pickup"
     deliveryMode = new NotificationDeliveryModeRequest
         transportType = "WebHook",
         address = IncomingCallWebHookAddress
But this seems to only set up the webhook to be fired for events on this one user's extension, even though the user is a Super Admin.
Is it possible to set up this webhook so that it fires each time an incoming call comes in for the over 100 users in our organization? It seems like this would be a nightmare to manage long term unless I can just have the super admin grant permissions for all extensions.
Thanks in advance!
  • July 10, 2019
Just change the event filter with this:
"/restapi/v1.0/account/~/incoming-call-pickup"
Make sure you login with a super admin extension.
Thanks Phong - Changing to the below worked for me.
  • August 4, 2021
Is this EventFilter still valid? "eventFilters":["/restapi/v1.0/account/~/incoming-call-pickup"]
I got a Bad Response error
"errorCode":"CMN-101","message":"Parameter [eventFilters] value is invalid","errors":[{"errorCode":"CMN-101","message":"Parameter [eventFilters] value is invalid","parameterName":"eventFilters"}],"parameterName":"eventFilters
  • August 4, 2021
If I wanted to get notified every time an outbound call is made for any of our extensions, can I use this?
"/restapi/v1.0/account/~/extension/~/telephony/session"
  • August 4, 2021
For getting notification on every extension, use the Account level event filter
/restapi/v1.0/account/~/telephony/sessions
For getting only outbound calls, use the direction params
/restapi/v1.0/account/~/telephony/sessions?direction=Outbound
  • August 4, 2021
Thanks Phong.
Was missing leading "/"
  • August 4, 2021
All,
Not sure about the "incoming-call-pickup" event anymore but it seems that it is not supported.
To receive an event of a call gets connected, simply use the /telephony/sessions event filter with the direction=inbound, then detect the connected status of a call
/restapi/v1.0/account/~/telephony/sessions?direction=Inbound
Read this article for further info about telephony session notifications.
  • August 4, 2021
Actually, your filter was missing the 's' as it must be '/sessions'
Hi ​@PhongVu,
I registered an app in the Developer area and gave it some permissions.
I ran /restapi/v1.0/account/~/telephony/sessions but it only applied the subscription to the Super Admin account, and when I tried /restapi/v1.0/account/700514067/telephony/sessions for example, it gave the error:
"errorCode": "SUB-406",
"message": "Not allowed subscribe for events to extensions of other account"
Can you advise of where I might be going wrong?
  • May 15, 2025
Hi ​@PhongVu,
This event filter “/restapi/v1.0/account/~/telephony/sessions” is the account level subscription, so you will get notifications of all users’ telephony sessions.
You don’t really need to set the account id “/restapi/v1.0/account/[accountId]/telephony/sessions” and I don’t believe that this id “700514067” is your account Id.
Remember that in RingCentral, account means “the company” and extension means “an employee” (a user)
You can learn more about the telephony session events from this article.
Ah that makes sense to me now, I didn’t realise the difference between accounts and extensions properly. It’s all working now 😀 thank you.
