Ringcentral Automator Server Error
  • January 6, 2025
  • 10 views
I just want to have a simple automation set up in the ringcentral automator app. It won’t turn on. It only says “server error” and nothing can be turned on or off.
  • 13 replies
  • January 6, 2025
Hi ​@aretelawncare Can you submit a feedback by the google form https://forms.gle/kvUXtxsHHXUYfqsR6 to share your RingCentral login email, so we can help you to clear the error?
We have a known issue that user can’t toggle automation if some extensions that you have setup automations is removed in RingCentral admin portal. We need to email to check and clear the error in our side.
