After Call Wrap-Up Time is not working in MVP
Hello,
I have the MVP product and am having issues with "After Call Wrap-up Time" set at the queue level. It is set to 3 Min, but I am getting reports that the queue users get no time before being placed back as available. To date this has never worked for them. They are placing themselves as DND as a workaround.
Is there a dependent setting somewhere I have not found. I have searched the downloadable manual, RC University and the Community. I don't see this issue being raised or addressed elsewhere.screenshot-2023-07-18-105520.jpg
  • 123 replies
  • July 19, 2023
I believe After call wrap-up time applies only to call queues. If your users are also receiving calls to their direct numbers it would still ring them. Would have to check the Reports > Call logs > Detailed view and confirm that is the case (or just ask them).
If your users are actually getting calls through the call queue during the wrap-up time, this would seem like a bug.
  • December 13, 2024
I am having the exact same problem. My Customer Care queue agents are getting queue calls and reporting that they often immediately receive another call as soon as they hang up. The system seems to be ignoring the 3 minute After Call Wrap-Up time that I’ve set. Their workaround is to go into DND. How can we fix this?
Problem Solver
  • 103 replies
  • December 14, 2024
@Ken13
there’s a good chance that wrap up isn’t working for you because of a user error/misunderstanding how it works. If you want to solve this issue I recommend you have 1 of your Customer Care agents share screen with RC support and reproduce the issue for RC support to see. They should be able to instantly tell if you are doing something wrong… and if RC support doesn’t notice any user error then they can troubleshoot it.
