Cisco ATA 192 Troubles
Recently RC has stopped offering the normal Polycom ATA devices we use for fax machines. I was told the Cisco ATA 192 would offer the same functionality.
On multiple devices we have discovered that the internet out port on the device (labelled as "Ethernet" on the device) does not seem to function. I have spent the last week plus poking around in the online configuration utility and I cannot get this to work. I can get the device online, I can fax in and out, everything works other than the port on the device that is supposed to be used for another device to access the web will not allow a connection. I believe this has something to do with the IP address on the port being assigned to a weird value.
I am still waiting on a solution from RC Support. This has stopped all fax conversions currently so hoping that either 1) there is a solution already from someone on this board or 2) help others who are stuck with this issue.
Hi Andy,
Thank you for bringing this to our community. I have thoroughly reviewed your case with our Tier 2 team and I am sorry for the delay in resolving this issue. I will personally reach out to them and request an update on progress.
We were also given the CiscoATA 192 for fax. At one location I had to manually update the firmware on it just to get it to work. The Ethernet port doesn't work either. I am guessing this has to do with the ATA trying to do DHCP its self. It should be acting as a passthrough and it isn't and once the ATA provisons to ringcentral I can't log into the ATA anymore to play with the DHCP.
  • September 19, 2023
Did ever have any luck? I am on hour #3 with my fourth support tech and they are still trying to get the pass through port to work.
  • October 2, 2024
Was there ever a solution to this?  I’m experiencing this issue now, and the first-level support team does not comprehend it when I explain it.  The Ethernet port works, you auto-provision the ATA via the portal, and the Internet via the Ethernet port stops working.
  • 86 replies
  • October 2, 2024
In order to re-enable the port, you will need to log into the device via its IP + admin password after it has successfully registered to RingCentral and do the following:
  1. Network Setup → Basic Setup → Networking Service dropdown
  2. It will say “NAT”
  3. Change it to “Bridge”
  4. Submit/save
The device will reboot, and potentially grab a new IP depending on how your network is configured. But after that, you’ll have access to both ports as LAN ports.
  • March 24, 2025
I bought a Cisco 192 ATA with the EX license for our dedicated fax machine. After having spent at least one week and numerous hours with RC support, it still does not work.  Can someone help.
Crystal_
  • 54 replies
  • March 26, 2025
Sorry to hear you're having trouble with your Cisco 192 ATA setup. Since you've already worked with support, we recommend escalating the case for further investigation. Please send me a private message with your account details and case number, and we’ll coordinate with our support team to assist you further.
Let us know how we can help!
