Replace Yealink Phone
  • July 15, 2022
  • 222 views
I need to replace a Yealink phone that has failed. How do I do that ?? What phones are compatible with this service?? I cannot find any resource to purchase a new phone .
If your phone is purchased from RingCentral, you can submit a ticket about your issue at https://support.ringcentral.com/new-case.html. You may also check the KB article below for the list of certified and supported deskphones for RingCentral.
https://support.ringcentral.com/article/certified-supported-deskphones-ringcentral.html
View original
