Reset Voicemail PIN - option not available?
This question seems to have been repeatedly answered years ago, but the interface in Ring Central Admin does not match the solution nowadays.
Where do I (admin) reset a users voicemail PIN?
This option used to exist previously, but now when I search for it, the option no longer exists (for any user).
I am looking in ‘Users with Extension’ then Phone then Voicemail Settings.  But there is no option to reset PIN.
Problem Solver
  • 103 replies
  • July 26, 2024
Users with extensions > User details > Security > Change Password and PIN.
You’ll first have to enter your own password, before being able to change the credentials of another extension.
Hey @JamesMounsey! Did the guide shared by @Problem Solver help you out? If it did, to show your appreciation, please consider marking it as the “Best Answer”. 🙌
  • July 30, 2024
Does this ‘Security’ option appear for all users, or only users after they have registered and created an account themselves?
I can see this ‘Security’ option for some users, but not all.
Problem Solver
  • 103 replies
  • July 30, 2024
yes, Security option is not visible for users who have Grey status (Not activated). This means they have never set themselves credentials via the Welcome email.
