Rule to Send Unknown Callers to Voicemail?
I would like to be able to automatically send all unknown callers to voicemail. Is it possible to accomplish this with a rule? Yes I am aware that I can block callers, and I also have call screening enabled, but that does not stop nuisance callers from distracting me all day long.
Thanks!
Joe Cache
  • Brainy
  • 154 replies
  • July 8, 2024
Looks like there isn’t that specific type of rule in there just yet - the closest thing is to ask them for their name, under the User/Phone tabs:
From a programming stand point, that would be somethinthey would program in the ‘Custom Rules’ - but they have the old logic from before - the three segments to look at - caller, number, and/or time.
I would write it up in more detail and post it on their Idea boards - I’ve seen many of them actually added to the core programming.
  • 86 replies
  • July 9, 2024
If you go to your Screening, Greeting and Hold Music section and click "blocked calls", there's an option for blocking calls with no caller ID. You'd select the "calls and faxes" option from the dropdown and it will send those calls to a disconnect message.
Not quite the same as your VM, but maybe that's good enough for you.
  • 728 replies
  • July 11, 2024
Thanks, @Joe Cache and @tak-it1 for jumping in here.
@Mr. Question Did their recommendations help you? If so, can you mark the one that addresses your use case as “best answer”? This can help other customers who share your use case to get the answer they need!
And if not, please let us know how we can help further.
