Jul 1, 2025 4:27 PM UTC
Automatic Notes & Transcripts Settings: setting from admin panel doesn't work
I’m building an integration with RingCentral and JobTread for a client, and I’m trying to configure the RingCentral settings so that Automatic Notes & Transcripts are always enabled at an organization level. Since there’s no organization-level option for enabling this, I’m wondering how else I can accomplish this.
I originally thought I’d have to do this by instructing each user to go to RC App → Settings → AI → Automatic Notes and Transcripts and enabling it, but I saw that there was a new setting on the admin panel, where we can go to the RC Admin Portal → Users → User List → Users with Extensions (or without) → click a user → Expand the AI section → click the AI assistant heading → Enable AI Assistant and Automatic Call Notes. I thought this would at least allow the company administrator to be responsible for enabling this setting, but when I made the change I saw that the Automatic Notes & Transcripts setting was still disabled on my (user) RC app instance (in RC App → Settings → AI). So now I believe the way to do this for now is by instructing each user to change their settings themselves as just described rather than using the admin portal to enable it. Is this the best way to do this?
I’m also wondering about where this setting is stored. I want to ensure that the Automatic Notes & Transcripts setting is stored at the user account level, and not on an application level, so that if they enable it in their desktop RC App, the setting is also enabled on their phone RC instance. Does anyone have any insight into this? I’ll have to test it manually for now I guess, but figured I’d ask.
Extra complaints that are less relevant to this inquiry included below:
I also need to enable automatic call recordings at the organization level, which sadly there is also not a setting for. Instead I need to ask them to manually check off each extension they want to record, so they have to remember to go into their settings and enable this every time they add a new extension.
RingCentral support hasn’t gotten back to me on any of this, and its been a week :(
Let me know if anyone has any thoughts! Thanks.
Jul 2, 2025 8:05 PM UTC
Hi ​@mh550,
Thanks for your questions about controlling Automatic Notes & Transcripts and Call Recordings centrally! These are really good questions, and I can definitely help clarify how RingCentral handles them.
Here’s a direct look at your points:
1. Automatic Notes & Transcripts (AI Assistant)
  • Admin Setting: The admin panel setting you found actually just enables the option for the user to use the AI Assistant. It's like giving them permission.
  • User Action Needed: To turn on "Automatic Notes & Transcripts" for a user, they still need to enable it themselves directly in their (RC App > settings > AI section). This is how it works currently.
  • Setting Syncs: The good news is, this setting is stored with their user account (in the cloud) and will automatically sync across all their RingCentral apps (desktop and mobile)!
2. Automatic Call Recordings (Organization Level)
  • Central Control: You're right, there isn't a single "always record everything for everyone" switch for all extensions.
  • Best Approach: For consistent organizational recording, the most effective way is to set up Automatic Call Recording Rules ( Phone System > Call Recording ) in the Admin Portal). You can apply these rules to your main numbers or Call Queues, ensuring all calls through those lines are recorded automatically.
And I'm sorry to hear about the delay you've experienced with support. Please do keep following up on your ticket!
I hope this helps clarify how to get these important features set up for your team! Let us know if anything else comes up.
Hi ​@mh550,
mh550The First StepAuthor
Jul 17, 2025 5:35 PM UTC
Hi ​@Mary-Community_Moderator,
Thanks for your detailed response! I really appreciate it.
I also have one more question: for call details (for the notes & transcripts), how are permissions handled? I’d like all members of my organization to be able to view all other members’ calls-- is this the default behavior with RingCentral? If not, is there a way to enable this?
Jul 17, 2025 10:50 PM UTC
Hello ​@mh550
It is possible for non-admin members to view other members' call details, notes, and transcripts, but it is not the default behavior.
An Administrator must explicitly grant this permission by:
  1. Logging into the RingCentral Admin Portal.
  2. Going to Users > Roles.
  3. Editing or creating a custom role.
  4. Enabling permissions like "Company Call Log - View Only" and "Company Call Log - Access Recordings".
  5. Assigning this custom role to the members who need this visibility.
So, while it requires an Admin to configure, it is a feature that can be enabled for non-admin users.
Jul 18, 2025 3:11 PM UTC
Thank you so much. I tried the method you described and didn’t quite get the behavior I expected.
I did what was described, by:
1. Making a new role from the “Standard (International)” template
2. Adding the permissions for Company Call Log for everything except deletions
3. Assigning this role to all non-admin members of the company.
My intended use case, which I didn’t fully describe, is to be able to access the call details page for any call made from the company/account, from any user/extension on the account. After this, I’m starting to sense this may not be possible. The reason for this is to allow any user of the company to view the notes & transcripts accessible from a call details page, such as https://app.ringcentral.com/calls/recent/ringex/all/{{call_id}} .
Since RingCentral doesn’t have an endpoint to access the transcripts or notes that they’re already generating for calls (when the setting is enabled), I have been generating my own transcripts using the recordings, extracting a summary + action items, and making a call entry in our client’s job management software logging the call w/ the summary + action items, and a link to RingCentral’s call details (with the dynamically generated link above).
I was able to log in to the admin portal from a user account with this new Standard + Call Log Access role. There, I still can only see 3 calls from my user extension, and 1 call from the super admin’s extension. I’m not sure why this is the case. But this still doesn’t have the notes & transcripts, just the recording.
So, is there a way to access notes & transcripts on an account-wide level?
Jul 18, 2025 5:06 PM UTC
​@mh550
Thank you very much for providing that extra detail about your intended use case and the behavior you observed. That's incredibly helpful!
I understand you're looking for a way for non-admin users to access the full call details page, including AI Notes and Transcripts, for any call made across the company, via a direct link or comprehensive view.
I'm currently looking into this specific scenario with our internal teams to get a definitive answer on whether that level of access to all users' call detail pages (with AI notes and transcripts) is possible for a non-admin role, and if so, the exact permissions required.
Please bear with me while I gather this clarification. I'll get back to you with an update as soon as I have a confirmed answer.
Jul 18, 2025 10:22 PM UTC
Thank you!!! I appreciate it. We can build a workaround if needed, but it would really be really nice to have this functionality.
Jul 21, 2025 4:16 PM UTC
Hello ​@mh550
Thank you for your patience while I gathered this information.
To access notes and transcripts on an account-wide level for non-admin users, you'll need RingSense AI. Simply having "Company Call Log" permissions isn't enough, as those typically don't include the detailed AI notes and transcripts across all users.
Here's the short explanation:
  1. RingSense AI is required: AI-generated notes and transcripts are part of RingCentral's RingSense AI offering.
  2. Specific Permission Needed: Your administrator must assign a custom role to non-admin users that includes the "RingSense for Sales - Access Insights" permission. This permission allows access to RingSense data (including notes and transcripts) for any user with a RingSense license across the account.
  3. API Access Available: RingCentral also offers the RingSense API if you need programmatic access to these notes and transcripts for integration with other systems.
In essence, enable RingSense AI and configure a custom role with the "RingSense for Sales - Access Insights" permission for your non-admin users to grant them account-wide visibility of AI notes and transcripts.
