how do i get the mobile ring tone volume to adjust its to loud.
Page 1 / 1
Hi Landon,
What kind of phone are you using? The iOS app uses call kit, and will reflect whatever settings you have on your phone.
Using an iphone. so if i adjust my ring volume it will work? also is there an adjustment in the app that makes the app not over
ride the screen?
ride the screen?
