How to play audio prompt in work flow based on variable value?
  • April 25, 2025
  • 133 views
Hi
I am working on a workflow that has some JS and I need to play different audio file greeting based on the DNIS of the incoming call.
I am able to handle the DNIS and put in if condition for it but I am not able to play the audio prompt in the next node.
get
var P3 = "Name_of_Audio_File"
 And the next node is as follows
When I test call the workflow I get no audio.
Has any one been able to play audio file by using the file name in an a variable ?
  • October 28, 2025
While not exactly the same, we do not use DNIS to play different prompts, we are able to apply a different variable in our JS.  Rather than using the var command we use “ivr.putData("menu","Name of Audio File") in the script which might be something to consider.
