API to add a custom rule to a specific site
  • December 12, 2024
  • 7 replies
  • 29 views
Not sure if im just missing it but is there a way via API to add a company number for a SPECFICI Site.
We are a multi site environment and we need to abaility to quickly add Holidays at a site basis.
Doing this at a queue level is not acceptable as when its out of hours it counts the call as abandoned and skews any metrics…
I can add one as a company number but this adds it under the main site..
  • 2331 replies
  • December 12, 2024
I don’t fully understand your question nor your use case.
But you can try this API to assign/reassign a phone number to a site.
  • Inspiring
  • 9 replies
  • December 12, 2024
Hi Phong,
Apologies i should explain better,
I need the ability to quickly add and edit call handling rules for a site. It can be done as a company but i can't figure out if it's possible to select the site itself.
  • 2331 replies
  • December 12, 2024
You can read site call handling rules using this API. Read the sites and use the site id of a site as the [extensionId].
Then call update call handling API to change/edit.
  • Inspiring
  • 9 replies
  • December 12, 2024
Yes but that requires one to be added to each site, my assumption is we cannot add one?
  • 2331 replies
  • December 13, 2024
So confusing. Here is what you asked “I need the ability to quickly add and edit call handling rules for a site.” and now you said “one to be added to each site” ???
  • Inspiring
  • 9 replies
  • December 13, 2024
Editing rules I understand can be done but adding a new one for a specific site?
Not sure what's confusing? It doesn't matter if it's one or Mutiple, id still need to run a separate API call for each rule ID
  • 2331 replies
  • December 13, 2024
There are many APIs under the Call Handling Rules section. Next to the Update API is the List, Create, Delete etc.
