C#: Resource for parameter [extensionId] is not found
  • August 7, 2020
  • 1589 views
I am trying to pull users presence data in C#
I was able to get the AccountId and the ExtensionId from here:
Here is my code:
using System;
using System.Threading.Tasks;
using RingCentral;
namespace Send_SMS
    class Program
        const string RINGCENTRAL_CLIENTID = "<>";
        const string RINGCENTRAL_CLIENTSECRET = "<>";
        const string RINGCENTRAL_USERNAME = "<>";
        const string RINGCENTRAL_PASSWORD = "<>";
        const string RINGCENTRAL_EXTENSION = "<>";
        const string RINGCENTRAL_PRESENCE_USER = "<>";
        const string RINGCENTRAL_PRESENCE_EXT = "101";
        static RestClient restClient;
            restClient = new RestClient(RINGCENTRAL_CLIENTID, RINGCENTRAL_CLIENTSECRET, false);
            restClient.Authorize(RINGCENTRAL_USERNAME, RINGCENTRAL_EXTENSION, RINGCENTRAL_PASSWORD).Wait();
            get_presence().Wait();
        static private async Task get_presence()
            // OPTIONAL QUERY PARAMETERS
            ReadUserPresenceStatusParameters readUserPresenceStatusParameters = new ReadUserPresenceStatusParameters
                //detailedTelephonyState = true,
                //sipData = true
            var response = await restClient.Restapi().Account(RINGCENTRAL_PRESENCE_USER).Extension(RINGCENTRAL_PRESENCE_EXT).Presence().Get(readUserPresenceStatusParameters);
            Console.WriteLine("Presence for Test Account: " + response.presenceStatus);
Everything in <> is filled out of course, and tested with the SMS_Send tutorial.
My error:
Content: {"errorCode":"CMN-102","message":"Resource for parameter [extensionId] is not found","errors":[{"errorCode":"CMN-102","message":"Resource for parameter [extensionId] is not found","parameterName":"extensionId"}],"parameterName":"extensionId"}
Thanks in advance. I'm really struggling to understand the account/extension side of this API.
Best answer by Anirban2396911020
This is because you are not giving correct extension id number. You can get all the id numbers for all your extensions with this API
GET https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~
It will return response with account id number and extension id number. example:
"uri": "https://platform.devtest.ringcentral.com/restapi/v1.0/account/123456789/extension/987654321",
account id number will be 123456789 and extension id number will be 987654321
