Calls not answered after idle time
  • July 5, 2024
  • 8 replies
  • 291 views
Hello. We are using https://github.com/ringcentral/ringcentral-softphone-ts for answering the phone. But after some idle time at night (like 12 hours or so) if we call this phone number the call is not answered automatically.
this.softphone.on('invite', async (inviteMessage: InboundMessage) => {
Could you please help us how we can make sure that we are answering the calls even after some time that sever is running?
Thanks.
  • July 5, 2024
Do you run on an online server or on your local machine? My test app runs on my laptop and it runs for days, overnights etc.
I will check with the owner of the SDK to see if he knows any solutions but I am sure that it’s related to the environment, not the SDK itself.
Meanwhile, can you implement a call function and test an outbound call to see if it’s successful when the inbound call fails.
  • July 5, 2024
We run the server online, the sever did not stopped for that time, I double checked that.
And it still answers the call every time without restarts? Because in our case it just stops acepting the answers after some time. Maybe it’s only when the is no calls for some time.
Thanks, I am waiting for the answer.
Could you please clarify what do you mean here?
  • July 5, 2024
Yes, I could receive and accept inbound call after days of running continuously.
I mean make a test outbound call while your app is still running and could not receive/answer inbound calls
https://github.com/ringcentral/ringcentral-softphone-ts/blob/main/demos/outbound-call.ts
  • July 5, 2024
Thanks.
Are you register `softphone` just once when app starts and you do not restart your sever? Right?
  • July 5, 2024
Thanks.
That’s right.
Turn on debug mode: https://github.com/ringcentral/ringcentral-softphone-ts/blob/main/demos/inbound-call.ts#L12
Make sure that you can see SIP messages.
By default, the client will send register message every 3 minutes: https://github.com/ringcentral/ringcentral-softphone-ts/blob/main/src/softphone.ts#L81
I don’t know what is wrong until you capture the SIP messages.
  • July 11, 2024
Thanks, I will check this out.
  • July 17, 2024
Thanks, we can see all debug logs.
It seems like this is the separate issue and it happens only when we configured redirect from main line to this user with softphone. I created a separate topic about this issue.
