Choosing right sdk or library for Golang
  • August 8, 2022
  • 496 views
Dear community,
I need to develop a server based webhook call monitoring application. Golang will be used as a progamming language. I did a research on available sdks and libraries for Golang and i like this one: https://github.com/ringcentral/ringcentral-go/blob/master/ringcentral.go although it is not mentioned as an official sdk on the https://developers.ringcentral.com/guide/sdks. Is it considered obsolete? If no, then why it is not on the sdk page? I need something well tested, reliable and simple. Or would you rater recommend to use one of the community provided SDK?
Thanks.
Best,
Nikolai
Best answer by PhongVu
That Golang SDK is not a RingCentral official supported SDK and yes, it can be considered as obsolete because it is not updated nor maintained.
You can clone/fork and use this SDK developed by an ex-RingCentral expert. If you have questions, you can create issues directly to the owner repo.
  • August 9, 2022
Thanks for this one, Phong!
