ConnectWise & RingCentral integration
  • January 22, 2025
  • 45 views
We are currently evaluating how to leverage the ConnectWise PSA with RingCentral for Voice. We want to be able to click-to-call out of ConnectWise and integrate our RingCentral DID’s, possibly automate some of the call-logging as well. Is this possible to do with ConnectWise open API? ConnectWise pointed me in the direction of RingCentral integrations directly.
  • January 31, 2025
Based on my experience you can do click to dials etc with the web-based version of the PSA and the soft phone on.  But there is not a good way to automate the call logging as there is with some other platforms. This has been on my wish list as a RC partner for a while, I’m looking at the possibility of developing something internal, but RC also has tight controls on how many API calls can be made at any give time.  I was trying to do a dashboard integration with Real Time Presence information from RC into a Dashboarding tool. I’m not going to say which one, but I’ve used a couple external to RC and you can’t poll the API’s frequently enough for real time activity to be worth it.  Just my nickles worth.
  • 250 replies
  • January 31, 2025
@ellie-mansour You might also consider using the RingCentral App Connect framework. This integration framework is designed around this type of integration design pattern. The framework is described in detail here:
And you can ask questions of the community here:
In summary though:
  • Customers install a Chrome extension created and maintained by RingCentral
  • Developers provide an adapter that can be insalled by customers into the Chrome extension
  • The adapter’s job is to perform customer/contact look ups, log calls and SMS, and a few other functions
Developers like it because:
  • Developers do not need to build a UI - just focus on a server bridge to the connected system
  • Adapters take about 1-2 weeks to build
  • The framework is constantly being enhanced independently by RingCentral adding more and more capabilities to make customers happy
