Getting token revoked error while using restapi/oauth/token with refresh token flow
  • June 21, 2022
  • 264 views
while using restapi/oauth/token api with refresh token flow, we aRe getting token revoked error.
The problem I have faced is few of the api calls are errored {'error': 'invalid_grant', 'errors': [{'errorCode': 'OAU-211', 'message': 'Token revoked'}], 'error_description': 'Token revoked'} error.
There is no description about this error and I couldn't find any solution from the dev forum. We are not using any revoke api's, I was trying to figure out why token is getting revoked when I use ouath token api.
  • June 21, 2022
How many active tokens do you have for the user for that app? If it exceeds 5, tokens might be revoked.
