How to use RingCentral and Reactjs?
  • May 3, 2017
  • 8 replies
  • 1952 views
Hi guys,
I'm trying to build a simple app in reactjs that uses RingCentral to make calls.
I'm having a hard time trying to login and make a call (not a ringout). I'm new to react and javascript as well.
Do you guys have any working example that I could use?
Thank you all.
There is a project which provides reusable React components: https://github.com/ringcentral/ringcentral-js-widget
It's a public project however it's not officially published. So it's just FYI.
  • February 15, 2021
Hello , If you have not able to made an app then get in touch with infomaze and hire mern stack developers for Developing the React JS Applications
  • November 8, 2022
@Tyler Liu I have started building new react project using the https://github.com/ringcentral/ringcentral-js-widgets#readme. I am getting the below error when I start the application using "yarn start". I see the "getLanguageFromLocale" method exists on github in i18n package, but that library is not getting downloaded into node_modules folder. Please suggest.
If you just want to write a React app, please refer to https://github.com/tylerlong/ringcentral-web-phone-demo
It is a simper demo application.
  • November 9, 2022
Thanks @Tyler Liu . I am planning to use ringcentral-js-widgets and override some of the behavior of those widgets. Ideally I want to build customized SMS widget which has some policies applied like (message templates, adding signatures for each message, populate the names and metadata for the incoming phone numbers from a database, etc).As per my understanding, I can't use the web-phone project for this scenario and I have to use widgets project. Please correct me if I am wrong.
If you prefer DIY, then you may use the web-phone library to build a phone and call Restful API to provide sms and other features.
If you prefer something that works out of box yet customizable, please refer to https://github.com/ringcentral/ringcentral-embeddable
  • November 11, 2022
@Embbnux Ji when I try to add conversationPage , I am getting below error. Please suggest if any other dependency need to be updated.
Uncaught TypeError: Cannot read properties of undefined (reading 'getUIProps')
at Function.eval [as mapToProps] (connectModule.js?bdd1:25:1)
at mapToPropsProxy (wrapMapToProps.js?2425:41:1)
at Function.detectFactoryAndVerify (wrapMapToProps.js?2425:50:1)
at handleFirstCall (selectorFactory.js?7906:22:1)
at pureFinalPropsSelector (selectorFactory.js?7906:63:1)
at Object.runComponentSelector [as run] (connectAdvanced.js?fe33:22:1)
at Connect.initSelector (connectAdvanced.js?fe33:182:1)
at new Connect (connectAdvanced.js?fe33:119:1)
at constructClassInstance (react-dom.development.js?61bb:12716:1)
react-dom.development.js?61bb:20085 The above error occurred in the <Connect(ConversationsPanel)> component:
at Connect (webpack-internal:///./node_modules/react-redux/es/components/connectAdvanced.js:126:28)
  • November 15, 2022
@Embbnux Ji @Tyler Liu Any inputs on the above error while adding Messages module . I am adding messages modules like below in containers/App/index.ts file.
<Route
path="/messages"
component={(routerProps) => (
<ConversationsPage
showContactDisplayPlaceholder={false}
showGroupNumberName
