Problem with Update Extension Caller ID
  • November 13, 2019
  • 402 views
I am using CURL in the developer portal and keep getting an error that the phoneNumber is invalid. What a I doing wrong?
Code:
curl --request PUT
  --url 'https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~/caller-id'
  --header 'accept: application/json'
  --header 'authorization: Bearer [[CODE]]'
  --header 'content-type: application/json'
  --data '{"byDevice":[{"device":{"id":"803563698037","uri":"https://platform.ringcentral.com/restapi/v1.0/account/179610037/device/803563698037","phoneNumber":"Ext. 101 Other Phone"},"callerId":{"type":"PhoneNumber","phoneInfo":{"id":"2025731036","uri":"https://platform.ringcentral.com/restapi/v1.0/account/179610037/phone-number/2025731036","phoneNumber":"+19703002096"}}}]}'
Error code I get back is
"errorCode":  "CMN-101"
"message":  "Parameter [phoneNumber] value is invalid."
"parameterName":  "phoneNumber"
  • November 13, 2019
error code I get back is
"errorCode":
"CMN-101"
"message":
"parameterName":
"phoneNumber"
  • November 13, 2019
I think the API reference is incorrect. While waiting for the dev team to confirm and make change to the doc, can you try to remove the "uri" and "phoneNumber" key/value pair from the "device" object. I think the "uri" and "phoneNumber" from the "phoneInfo" object can be omitted as well.
Please try and let me know
