SalesForce Integration Ringer Sound Change?
  • September 13, 2023
  • 306 views
The ringing sound in the Salesforce integration is so loud and is not adjustable in the integration. When someone is on a call with a customer and another call comes in, the SalesForce ringer is so loud that it makes people jump. Can we turn off the ringer in SalesForce? Or at least change it so that it's not so loud? Since it's ringing in conjunction with our other RingCentral apps, it going completely away would be fine.
Best answer by georgelu
To adjust the Ringtone volume please ensure that you are on the latest version for RingCentral for Salesforce - Version 6.29
Please navigate to Settings > Audio > Ringtone Volume
From here you can adjust the volume using the slider within the integration.
View original
  • January 18, 2024
I'm having the same issue, is there an option to adjust the volume similar to what is in the desktop app.
  • August 23, 2024
I am having the same issue and there doesn't seem to be a resolution 1 year later. RingCentral, Your up!
georgelu
  • August 26, 2024
