Sms read status change using sdk
  • September 11, 2020
  • 790 views
When we send any sms we can get the sms messages id in the response and i have noticed that in the response the status is always read by default:
"readStatus":"Read"
I am not sure why the default is read and what does it mean?
What are the way if I need to change the status into not read or unread ?
Can it be changed with java SDK?
There are basically 2 status: Read, Unread
When the SMS is send the readStatus is always "Read"
You can use the message store API to update the status of your message.
Check this API here:
https://developers.ringcentral.com/api-reference/Message-Store/updateMessage
Every SMS message have a messageId and you need to use that messageId to update the readStatus.
eg:
PUT https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~/message-store/<your message id>
You can change the status with this API. Also using SDK, you can change that.
Check the demo here in Java:
https://ringcentral-tutorials.github.io/sms-api-java-demo/?distinctId=1746f43bd51496-0f9334d92b97c8-f7b1332-144000-1746f43bd523ca#5
