Two-Legged RingOut Call using Asp.Net
  • January 29, 2016
  • 417 views
I want a sample or suggestion reg how to use Two-Legged RingOut Call API in my website using Asp.Net for my web applications. Thanks in Advance
  • Found Your Voice
  • February 2, 2016
We do have a C# SDK available, and there are examples for SMS, Fax, and other services offered by the RingCentral API resources. RingOut is a two-legged call. The SDK contains all the information you'll need to get started using it in your application.
The RingCentral C# SDK: https://github.com/ringcentral/ringcentral-csharp
Example request to establish a two-legged ringout:
Request request = new Request("/restapi/v1.0/account/~/extension/~/ringout", jsonRingoutString);
Response response = ringCentral.Post(request);
The API Documentation for Two-Legged RingOut which provides information you'll need when populating the JSON body of the POST request: https://developer.ringcentral.com/api-docs/latest/index.html#!#TwoLegRingOut.html
