What's the best approach to get notified when there's incoming call ?
  • May 16, 2025
  • 249 views
Hi folks!
I’m using: https://github.com/ringcentral/ringcentral-softphone-ts
I think I can get notified through TLS connection but if I’ve like 10k users connected their ringcentral, will I have to got 10k TLS connection (each with their own SIP credentials) ?
Is there any better alternative option to this like receiving an API call to my webhook or something ?
Thanks in advance!
  • May 16, 2025
Yes you can via the telephony event notification. Please read this article to learn more.
You can get notifications like Phong Vu said. But in order to answer calls using the softphone SDK, you need to start a softphone SDK instance which will create a TLS connection.
  • May 16, 2025
Thank you for prompt reply!
another quick question: are there any limits for this telephony event notifications ?
  • May 16, 2025
