Within Ringcentral MVP, is there a way to export via API or other method the call queue settings, for example Call queue details, pickup settings & members?
  • August 18, 2022
  • 417 views
  • August 19, 2022
Check out these call queue APIs:
List all call queue
Use the call queue id (group id) retrieved from the API above to read a call queue configs
Use the call queue id to read the call queue members
You can also update/change a call queue configs.
And here is the developer guide to get started
Hope this helps.
