Add "Hold for" behavior to IVR Menus,Allow "Hold for" behavior in IVR Menus
  • July 8, 2021
  • 320 views
Example:
Main IVR Menu:
"...Press 5 for Test Department..."
User presses 5 and is sent to another menu
Second IVR Menu:
"If you are calling in regards to SUBJECT1 please press 2. Otherwise, please hold for the Test Department..."
In this case, the user pressing 2 would direct transfer them to an extension for SUBJECT1 related matters. If no key is pressed within X amount of time (reasonably about 5-8 seconds), they would be directly transferred to Test Department call queue extension.
As of now, the only related behavior is if the user listens to the entire prompt 3 times without making a key press they can be transferred to another extension, which is a bit excessive.
Please add "Hold for" behavior in IVR Menus.
IVR Menus currently only have key-press behavior and no ability to have the logic be "If user has not pressed a key within x amount of time, direct transfer to x extension or y menu". Currently the only related behavior is if the user listens to the prompt 3 times..which is a bit excessive.
Thank you for sharing this. Please add it to our Ideas Portal at https://ideas.ringcentral.com/. To check all RingCentral's features, you can always visit https://support.ringcentral.com/.
  • April 6, 2023
https://support.ringcentral.com/app/admin/mobile/setting-up-general-ivr-settings-ringcentral-mobile-app.html
General IVR Settings
  • General navigation keys: Tap and select option for the following keypad prompts: Press # and Press *.
IVR settings
IVR settings
  • If the caller enters no action after the prompt is played three times: Select between Disconnect or Connect to Extension.
IVR settings
How can we change setting to connect to extension after playing only 1 time, instead of 3?
