How to see SIP settings of Softphone?
This is all you can see. Read your soft phone device id, then use the device id to call this endpoint.
If you are using BYOD, you can get sip credentials with this endpoint . You can also view sip crew for BYOD here :
https://support.ringcentral.com/article/Manual-Provisioning-How-get-SIP-Settings.html
6 People are following this question.
RegisterDevice creates a SIP device with no valid Emergency Address
Device SIP Registration API is giving "Device is not allowed for Other" error message
How to generate crypto key and encrypt/decrypt audio on SIP call with TLS 1.2?
Is it possbile to de-authorize a computer using C# API for Softphone?
