I get the "Dial is temporarly unavailable" error message when calling via WebRTC
  • March 22, 2022
  • 306 views
Hello so when i try to do a call with the app using WebRTC I get a message that says, "Dial is temporarly unavailable." I do not know how to fix this could you help? Thanks.
  • March 22, 2022
I edited your post to remove personally identifiable information. This may not be a developer issue. Can you confirm? Are you a developer working with the API, or a user trying to use one of our apps?
  • March 23, 2022
I can't find any suspect from your app analytics. Can you try the demo app as such to see if it works? Also, I see your app is in production, make sure that you use the correct app credentials and user credentials for your selected environment.
