Luke Homen avatar image
Luke Homen asked Yatin Gera answered
Feature Request: Auto-Ignore Incoming Calls When on the Line
Feature Request: Auto-Ignore Incoming Calls When on the Line.
Tech support says there's no way to do this. Here's what I want to do: when I'm on a call, I don't want to be interrupted by incoming calls. I don't want to have to manually press Ignore. Instead, I would prefer that RingCentral notice that I'm on the call, and automatically press Ignore.
call handling
1 |3000
1 Answer
Yatin Gera avatar image
Yatin Gera answered
Hi @Luke Homen
Thanks for sharing your feedback and we really appreciate such valuable feedbacks that make the product better.
RingCentral has a forum where you can submit ideas and as per the popularity of these ideas, the product development team picks them up
I would encourage you to share your idea on https://ideas.ringcentral.com/ for better visibility
1 |3000
Developer sandbox tools
