populate "to" phoneNumber for incoming fax messages
  • January 31, 2019
  • 218 views
For SMS and VoiceMail incoming message types, the "to" array's "phoneNumber" is populated with the proper phone number that the message was sent to. BUT, for incoming Fax messages the "to" phoneNumber is populated into the "subject" element and the "to""phoneNumber" element is not populated at all. Based on the API documentation, this is not correct. Can this be corrected in a future version of the API?
  • January 31, 2019
Hi Michel,
Thanks for the feedback! Absolutely right. I will check with the dev team to make sure these info will be available as they are documented.
+ Phong
