Block SMS: Is there a way to block a number from the text feature?
  • August 4, 2015
  • 448 views
I am getting texts in another language and want to block the number. All of the previous conversations I've found on this support center only address voice and fax features. Is there a way to block a number from the text feature?
  • August 4, 2015
There is no way to only block a number from texting only...but allow the voice call.  You'll have to block the entire thing (voice, fax, and SMS) under Screening, Greeting, and Hold Music.
  • August 4, 2015
Thank you!! Your quick response is much appreciated and your directions were simple :)
