cURL error when Integrating the PHP SDK on my project
  • December 11, 2015
  • 14 replies
  • 7569 views
I am Using RingCentral Connect Platform PHP SDK (https://github.com/ringcentral/ringcentral-php) to send fax messages, I get a curl error when i run the script. I have a developer account and testing the authenticate and Fax message and it works fine.
Error details:
Warning: curl_close(): 28 is not a valid cURL handle resource in <path_to_project>vendor
ingcentral
ingcentral-phpsrcHttpClient.php on line 104    Fatal error: Uncaught exception 'InvalidArgumentException' with message 'Invalid response string' in vendor
ingcentralpsr7srcfunctions.php:478  Stack trace:  #0 <path_to_project>vendor
ingcentral
ingcentral-phpsrcHttpApiResponse.php(56): RingCentralPsr7parse_response('HTTP/1.1 0 OK??')  #1 <path_to_project>vendor
ingcentral
ingcentral-phpsrcHttpClient.php(99): RingCentralSDKHttpApiResponse->__construct(Object(RingCentralPsr7Request), false, 0)  #2 <path_to_project>vendor
ingcentral
ingcentral-phpsrcHttpClient.php(25): RingCentralSDKHttpClient->loadResponse(Object(RingCentralPsr7Request))  #3 <path_to_project>vendor
ingcentral
ingcentral-phpsrcPlatformPlatform.php(214): RingCentralSDKHttpClient->send(Object(RingCentralPsr7Request))  #4 <path_to_project>vendor
ingcentral
ingcentral-phpsrcPlatformPlatform.php(301): RingCentralSDKPlatformPlatform->sendReq in C:inetpubwwwrooterexpresspublicvendor
ingcentral
ingcentral-phpsrcHttpClient.php on line 44
Sample code (basically the sample code from - https://github.com/ringcentral/ringcentral-php/blob/master/demo/fax.php):
<?php
use RingCentralSDKSDK;
require_once(__DIR__.'/vendor/autoload.php');
$credentials = require(__DIR__ . '/vendor/ringcentral/ringcentral-php/demo/_credentials.php');
// Authorize
$platform->login($credentials['username'], $credentials['extension'], $credentials['password']);
// Find Fax-enabled phone number that belongs to extension
$phoneNumbers = $platform->get('/account/~/extension/~/phone-number', array('perPage' => 'max'))
->json()->records;
print 'Fax Phone Number: ' . $credentials['username'] . PHP_EOL;
// Send Fax
$request = $rcsdk->createMultipartBuilder()
->setBody(array(
'to' => array(
array('phoneNumber' => $credentials['username']),
'faxResolution' => 'High',
->add('Plain Text', 'file.txt')
->add(fopen('https://developers.ringcentral.com/assets/images/ico_case_crm.png', 'r'))
->request('/account/~/extension/~/fax');
//print $request->getBody() . PHP_EOL;
$response = $platform->sendRequest($request);
print 'Sent Fax ' . $response->json()->uri . PHP_EOL;
  • Known Participant
  • December 11, 2015
Hi ,
Did you instantiate the SDK Object within the sample code that your are using to Authenticate and Send Fax :
Please include this code within your demo application :
// Create SDK instance
$rcsdk = new SDK($credentials['appKey'], $credentials['appSecret'], $credentials['server'], 'Demo', '1.0.0');
If you take a lookat our Demo Folder within the SDK you would see a file named "_credentialsSample.json" . Please make sure you are using all the details on your sandbox account like appKey, appSecret and the credentials on your sandbox account etc.
Also for your reference, i am providing a sample code below to Authenticate and Send Fax :
$credentials_file = count($argv) > 1         ? $argv[1] : __DIR__ . '/_credentialsSample.json';
        $credentials = json_decode(file_get_contents($credentials_file), true);
        // // Authorize
        $platform->login($credentials['username'], $credentials['extension'], $credentials['password'], true);
                 ->setBody(array(
                     'to'         => array(
                         array('phoneNumber' => 'toNumber'),
        print_r("Request");
        print_r($response->request()-> getHeaders());
        print_r("Response");
        print_r($response->raw());
  • December 14, 2015
Hi Anil,
Thank you for your response. I did instantiate the SDK Object. Somehow missed pasting it in  sample code above.
I get the same error when i substituted the reference code you provided
Fatal error: Uncaught exception 'InvalidArgumentException' with message 'Invalid response string' in vendor ingcentralpsr7srcfunctions.php:478
Stack trace:
#0 <path_to_project>vendor ingcentral ingcentral-phpsrcHttpApiResponse.php(56): RingCentralPsr7parse_response('HTTP/1.1 0 OK??')
#1 <path_to_project>vendor ingcentral ingcentral-phpsrcHttpClient.php(99): RingCentralSDKHttpApiResponse->__construct(Object(RingCentralPsr7Request), false, 0)
#2 <path_to_project>vendor ingcentral ingcentral-phpsrcHttpClient.php(25): RingCentralSDKHttpClient->loadResponse(Object(RingCentralPsr7Request))
#3 <path_to_project>vendor ingcentral ingcentral-phpsrcPlatformPlatform.php(214): RingCentralSDKHttpClient->send(Object(RingCentralPsr7Request))
#4 <path_to_project>vendor ingcentral ingcentral-phpsrcPlatformPlatform.php(301): RingCentralSDKPlatformPlatform->sendReq in C:inetpubwwwrooterexpresspublicvendor ingcentral ingcentral-phpsrcHttpClient.php on line 44
This error occurs when i try to call the
// Authorize call
  • Known Participant
  • December 14, 2015
Could you please provide the Organization Name or the sandbox number with which you are using the developer platform, we could take a look at your account.
  • December 15, 2015
The sandbox username is +18024486632. I tested the sandbox credentials on ringway API explorer : Send Fax. It works fine and I receive a fax.
  • Known Participant
  • December 15, 2015
I have created a sample Demo Application to Authenticate and send Fax .
Please take a look at the file named "sendFax.php" in the Github Repo and you could modify the code accordingly within your application:
https://github.com/anilkumarbp/ringcentral-php-demo
  • December 15, 2015
Hi Anil,
I copied your code and tried to run it.
Errors:
Error 1
 - Fatal error: Class 'RingCentralSDKSDK' not found in C:inetpubwwwroot ingcentral-php-demoappauthenticate.php on line 10
The vendor ingcentral ingcentral-php folder was empty, so i downloaded the zip file from https://github.com/ringcentral/ringcentral-php and pasted those files in the folder. The error disappears which leads to Error 2
Error 2 -
Fatal error: Interface 'PsrHttpMessageRequestInterface' not found in C:inetpubwwwroot ingcentral-php-demovendor ingcentralpsr7srcRequest.php on line 13
  • December 15, 2015
Hi Anil,
We have resolved the issue we came across while trying to integrate Ringcentral PHP SDK. The issue was caused due to cURL SSL certificate issue.
Curl error: SSL certificate problem, verify that the CA cert is OK. Details: error:14090086:SSL routines:SSL3_GET_SERVER_CERTIFICATE:certificate verify failed. Copied cacert.pem file and modified php.ini with the path to cacert.pem and it works.
Thank you for your support.
  • December 16, 2015
Can you tell me how i can format the fax message into a proper content with bold and next line
eg:
->setBody(array(
'to'  => array(
array('phoneNumber' => '12672800722'),
'faxResolution' => 'High',))
->add('Plain Text <Br> <b> Hello </b>', 'file.txt')
Right now the content shows up in the fax message as such:
Plain Text <Br> <b> Hello </b>.
Can we have html formatting:
Plain Text
Hello.
  • Known Participant
  • December 16, 2015
You are trying to add HTML formatting to a plain text. You could try replacing the "<" and ">" symbols with "&lt" and "&gt" respectively but i suppose that would work with the text file.
However, you could create a .pdf format file and you could have it included as your attachment before sending the fax.
  • December 17, 2015
Created a pdf file and as suggested included it as an attachment. Works as expected
  • December 21, 2015
Do we have an option of not displaying the cover page either through the PHP SDK or through the Ringcentral outbound fax settings?
  • Known Participant
  • December 22, 2015
You could set the 'coverIndex' parameter as part of the body to 0 (none- no cover page ) for not displaying the cover page when you send a fax.
Please take a look at our API Explorer to send Fax here :
http://ringcentral.github.io/api-explorer/#!/Messaging/v1_0_account__accountId__extension__extension...
  • December 22, 2015
Thank you Anil. That worked.
  • December 30, 2015
Can we remove the header from the fax message :
"From: ER Express Fax Fax: (xxx) xxx xxxx     To:   Fax: +1(xxx) xxx-xxxx Page 1 of 1 12/30/2015"
