Hold Issue on Conference Ph: Whenever a call is placed on hold, phone start ringing out
  • May 30, 2019
  • 12 replies
  • 1144 views
I've been having this issue with our conference phone for months and no rep is able to fix it. Whenever a call is put on hold, the person on hold hears continuous ringing as if the call is dialing out.
I've been able to set hold music/tones for regular lines but the conference phone doesn't show that option. Has anyone else had this issue??
  • Known Participant
  • May 30, 2019
What is the model of the phone anyhow did you provision it with RingCentral?
  • May 30, 2019
It's a  Polycom VVX311. We went through all the initial set up steps with RC
  • Known Participant
  • May 30, 2019
Can you share a screenshot of the Screening, Greeting & Hold Music section for that user?  I don't understand how you would not see the option for hold music.
  • Known Participant
  • May 30, 2019
You don't have to share anything sensitive or anything at all really.  Just look at that section and see if it looks like this or not.  I think the forum has a problem uploading images now, but you can see it here: https://imgur.com/4Nhifav
  • May 30, 2019
Sure, can you contact me directly? I'd prefer not to post a photo of our company poral/our phone numbers.
  • May 30, 2019
  • Known Participant
  • May 30, 2019
You need to look under the user, not the phone.  But, I see these are limited extensions which I am not very familiar with.  If you go to users can you find the Screening, Greeting & Hold Music section for 3005?
  • May 30, 2019
That line isn't under Users because it is not assigned to a user. It is a common area phone; listed under Phones & Devices.  Are you unfamiliar with this also?
  • Known Participant
  • May 31, 2019
I am not sure.  I see 3005 listed as assigned to the device in your screenshot.  I guess you can't see that user or if you can, you don't see the Screening, Greeting & Hold Music section?
Does that conf phone have a presence listed and is the box checked that says ring my phone when monitoring another phone?
  • June 3, 2019
There's not an Presence option for Common area phones
  • July 30, 2020
I have a different view. See below.
