Ring Central Audio phone number choices
  • 21 April 2020
  • 107 views
When you start a ring central meeting, there are 5 different U.S.phone numbers to connect to for audio. Does everyone need to select the same phone number to be connected? or will the Meeting ID connect everyone?
Userlevel 2
Hello Karen!
The Meeting ID will connect to everyone. Those 5 options are the numbers you can try in case one doesn't work.
