Ring group max size
  • November 5, 2020
  • 614 views
I want to have 14 extensions as part of 1 ring group and all ring simultaneously. How can this be set up?
Best answer by Anonymous
Hello @Sam Rippey! You can request to max up to 25 extensions, you can request it by opening a case HERE, and our phone support will contact you as soon as possible. Thank you!
  • November 6, 2020
