Problems incluing SDK in .exe in Python
  • February 18, 2020
  • 2295 views
Hello All,
Has anybody run into this?
I have a python app that sends SMS using the SDK, I want to make an executable out of it with pyinstaller, its not, as far as I can tell including the SDK in the build at leas there is nothing in the dist folder. Where should I be looking?
  • February 19, 2020
Not sure if anyone in this community has done that and can share experience with you. I recommend you to ask a generic question in stack overflow to get better advice.
Any python community forum may answer this question. I have also seen some YouTube video available regarding creating exe out of pyinstaller. Maybe someone from python community can help more specifically with this.
