Help Using Yealink W70B
  • February 23, 2024
  • 712 views
I would like to use the Yealink W70B to connect multiple handsets to the same line. I provisioned the base successfully, but cannot get handset to call out or receive calls. Anyone familiar with how to set this up, or if it even works this way?
  • February 24, 2024
The base has 3 lights which should be in solid green.
Then you just have to pair the additional handsets to the base. Try googling "ringcentral pair handset yealink"
