Is there a way to change an agent status from "Do not disturb" to "Available" using a DTMF code?
  • July 28, 2022
  • 259 views
If an agent is locked out of their computer and their Ring Central status is set to "Do not disturb." Is there a mechanism to set their Ring Central status back to available so they can receive phone calls on their physical phone? For example: 3CX allows DTMF codes to set status as away or online.
The article below contains the DTMF codes available as of now. You can submit a feature request at https://support.ringcentral.com/new-case.html.
https://support.ringcentral.com/article/901.html
View original
