problem with ring central unified
  • February 19, 2021
  • 129 views
problem when contact name is not filled in when adding a contact to ringcentral unified.
Sometimes the contact cannot be found and sometimes the contact be found only through scrolling and
not through search.
If the contact is found through search the contact profile initials is the area code instead of the company name.
PLEASE FIX THESE BUGS IMMEDIATELY IT'S REALLY ANNOYING AND IT MESSES UP MY CONTACT LIST THX!
Hi @Joseph Rosenfeld, I suggest for you to report this issue with our Technical Support Team so this will be investigated. All of our Support numbers can be found here. You can also create a support case here.
