Some, Not All, RingCentral Polycom Phones Occasionally Deregister and Lose Connection
  • March 21, 2025
  • 8 replies
  • 585 views
We use Ring Central Polycom VVX 450s across our organization. I have 2 phones that are occasionally de-registering themselves and stating “No Service” then moments later will come back up. I don’t think it has anything to do with PoE as the phones will stay on during this time. The firewall is allowing for connections out to the IP/Port. Would having inbound connections limited affect this? The phones are on two different switches. Again this is only happening to 2 phones that I’m aware of, out of the 90+ in our environment. Any help would be appreciated. Logs consistently state the following when the outages occur:
032****|sip  |4|00|CPlcmSipTcpSocket::ConnectThreadLocal Failed to connect to 104.245.57.227:5090 : Error[Operation now in progress] on SocketAddr (0x1a49940)
032****|app1 |4|00|Failure reason is Failed to connect to server : Error[Operation now in progress]
Best answer by Crystal_
Hi ​@sailorsam122,
It sounds like the affected phones may be experiencing intermittent network connectivity or firewall-related issues. Since most of your phones are working fine, but only two devices are deregistering, here are a few things to check:
  • Ensure inbound traffic is not being blocked.
  • Double-check firewall settings to allow SIP and media traffic from RingCentral's IP ranges.
  • If possible, test the affected phones on a known working switch port to rule out hardware issues.
  • Ensure the latest firmware is installed on the affected devices.
  • Try reprovisioning the phones in the RingCentral Admin Portal.
    If the issue persists, we recommend submitting a case for further investigation with our support team. You can do so here:
    🔗 Submit a Case
Crystal_
  • March 24, 2025
Hi ​@sailorsam122,
    🔗 Submit a Case
  • June 26, 2025
i wonder if you fixed the issue.  I have something like that in one of the branch offices, seems to be firewall related.
  • October 23, 2025
did anyone ever figure this one out?
having the same issues the past few weeks. Been running vvx450’s for around 6 years now, but this started happening recently on many across the org the past few weeks.
thank you all
thank you all
Hi ​@sailorsam122, please submit a ticket to our Tech Support team so they can take a closer look at this: https://support.ringcentral.com/new-case.html
  • October 23, 2025
thank you all
Thank you Mary, if you have a contact on that team, please let them know to review the ticket that has been previously submitted. Much appreciated.
  • October 24, 2025
Apologies for the late reply here, TLDR, the only thing that made a significant difference was adding a RC specific firewall rule with high priority, basically saying take any traffic from our Phone VLAN and if it’s destination matches Ring Central’s subnets, allow ALL outbound without inspection. I’d also check if your firewall has any application filters, that may also cause an issue if it’s snagging RC/Voice traffic. With those changes, now we only get 1 or 2 phones with this symptom, once in a blue moon, as opposed to all or many phones going down multiple times a week.
  • October 28, 2025
thank you all
My issue was during a move between suites in a same building - the fiber was supposed to be physically disconnected and routed to a new floor but somehow it was still connecting with IPv6 but not IPv4 so I had some but very limited connectivity.
  • October 29, 2025
We have 30 phones that deregister and register in moments, and randomly.  Network checked out. We updated 25 VVX450s to  version 6.4.7.4513.  So far, one of the 5 we did not update reported event.  Anyone have this issue?
