When will RingCentral coordinate with RedTail CRM for a true integration?
  • February 14, 2023
  • 300 views
It's a bit surprising that RingCentral isn't laser-focused on integrations through its app for every major CRM. For RedTail, all that is available is a dangerously insecure Chrome browser extension that doesn't actually work.
Best answer by Embbnux
You can try the new Chrome extension in Chrome webstore now:
https://ringcentral.github.io/rc-unified-crm-extension/redtail/
Forum|alt.badge.img+2
  • February 22, 2023
Sean,
Normally, I would point you to the Ideas Portal, but I see that you have submitted an idea about this integration.
Unfortunately, I don't see a ton of votes for this specific integration which means that we're not hearing about a lot of demand.
I would say that your best bet for the time being is to explore leveraging our open API and working with RedTail to develop.
If you have additional context you think might be helpful or use case information that would move the needle, please shoot us an email about it and I'll gladly share it with the integrations team for review.
  • August 16, 2024
