Can I Make 2 Yealink SIP T57w Phones Ring On The Same Extension In The Office?
  • October 16, 2024
  • 7 replies
  • 348 views
I use it as a “land line” of sorts and don't need 2 extensions for offices beside each other. I just want both office phones to ring if someone calls the toll free number.
the only reason I want a voip style phone is to track who calls the office and to forward call to my cell if im not at the office.
Problem Solver
  • 97 replies
  • October 16, 2024
you can assign multiple devices to a single extension.
Each device needs a license, so if your idea was to save costs on a license - that won’t work.
but if your idea was - “I don’t want to create another extension, because it is simpler to have both phones under 1 extension” then you can add a 2nd license (i.e. a 2nd digital line) to your user extension. To do so:
Go to users> click on your ext>Devices & numbers > add Phone>pop up opens.
In the pop up you have a step called Select devices. Here you most likely want to select Other phones > “Existing phone”. This makes sense if the 2nd phone is not bought from ringcentral, but from a third party.
Once you add the 2nd digital line head over to
Phone System > Phones & Devices > User phones
You’ll see both digital lines assigned to your extension. Click on the newly added one and then click on “Set Up and Provision”
  • October 17, 2024
Thanks!
When I go to
Other Phones
Existing Phone
I see select from account (available is 0) and additional purchase then it says (FREE) but when I make that “1” it adds this to the screen to the right as “devices added”
Domestic DigitalLine Unlimited 1 x $35.00 $35.00
Joe Cache
  • Brainy
  • 154 replies
  • October 17, 2024
How comfortable with the phone GUI are you?  If you are familiar with going into the phones IP and logging in, you can provision the other line without going through the RC panel.
The Yealinks have multiple lines that can be added   Once logged into the GUI:
change to the Account tab, and use the pull-down to select the next account.
This is where you’ll need the provisioning information that they were tralking about in the previous note.
You can also ask the RC chat about it.
You won’t need all the information - look back at the Account1 settings and you’ll be able to fill out the same fields (mostly) on the Account2
Once you have saved the info, near the top it will show ‘Registering’ and then ‘Registered’ when complete.  If it comes back in error, triple check your username/password - that’s where we’ve had the most issues.
This then gives you two lines - same phone - different extensions.  :)
Hope that helps.
Problem Solver
  • 97 replies
  • October 17, 2024
That’s exactly right. It means the Yealink device is free and you are only paying for the license.
License or digital line - same thing in my book.
I am going to repeat myself - if your idea was to save on the cost for a 2nd license- that won’t work.
What Joe is saying is about having multiple accounts on 1 yealink phone. The most common use case scenario for that is having 1 base station with several handsets.
By default all handsets of a base station would be assigned to account1.
But if you do what Joe is saying you can assign each handset to a different Yealink account. In other words each handset will have its own phone number and can be called individually. This also requires 1 digital line(license) for each Yealink account.
My understanding is that you are asking something different. I understood you are using 2 Yealink T57W and you want to assign both of them to your extension.
To do this you need to follow the steps in my first comment. The result would be that both phones would have a direct number, and by default no matter which number is called your extension would ring. (Similar can be achieved with 2 extensions and 1 call queue, or with 2 extensions and 1 ring group). The default call handling can be changed/ i.e. you can set it up so they ring one after the other, etc.
Example if you don’t want to pay for an extra digital line(license):
- you need something like a Yealink W76P with 2 or more handsets
- all handsets will ring at the same time
- only 1 license required
  • October 22, 2024
sorry maybe I was explaining the goal differently. I have an office with 2 rooms. Both have a yealink t57w and I just want both to ring when someone calls the main office number. I don't need separate extensions as we are rarely both in the office at the same time.
  • 20 replies
  • October 28, 2024
If both phones are assigned to two different extensions with two different numbers/licenses and you want both of them to ring when you main number is dialed, your options would be:
1. Re-assign the phone and number to the extension where the main line calls are routing. Since as mentioned above, we can assign multiple devices to a single extension as long as there is a number/license assigned to it.
2. You can set up call forwarding on the extension where calls are being routed and add the other phone as part of its forwarding number then set both phones to ring all together.
You can check this link to review how your main line calls are handled/setup to identify in which extension you need to set up the call forwarding or to re-assign the other device:
https://support.ringcentral.com/article-v2/Configuring-company-call-handling.html?brand=RingCentral&product=RingEX&language=en_US&pills-nav=admin_portal
This link is to check on how you can set up user call forwarding.
https://support.ringcentral.com/article-v2/Setting-up-how-incoming-calls-are-handled.html?brand=RingCentral&product=RingEX&language=en_US&pills-nav=admin_portal
Joe Cache
  • Brainy
  • 154 replies
  • November 1, 2024
Then yes, just adding another phone to the extension would work.
We have some extensions that have 3-4 physical devices located all about the site - so it is possible.
Hope that helps.
